I got my new towing mirrors from Leroy today. I bought a set of the "Plain Jane" no option mirrors. No power or lights to deal with. These will be very easy to transfer to other trucks when need be.
I also installed them this afternoon on my 94 k3500 srw. This will be my main towing truck for the near future.
This is what the mirrors looked like in the packaging. They are packed very well.:thumbsup:
View attachment 27246 View attachment 27247
After unwrapping them , I opened the hardware bag that have the nuts, long stud and brace piece. I put anti-sieze compound on the threads on the short end and screw it into the mirror mounting base. I tighten it with a vice grip on the smooth part of the stud.
View attachment 27249 View attachment 27250
Next up was to remove the old mirrors. To do that the interior door panel has to be removed. Lower the window first. There is one phillips head screw in the recess of the armrest. The power window /lock panel must come off first. I use a wide thin pry bar made for removing wood trim to pop the lock/window panel off. For the inner door panel I use a Wonder Bar prybar to pop the plastic panel retainers off. Once the panel is loose it must be lifted straight up to release from the window slot. The lock/window switch panel must be slipped through the opening in the panel .
There is a piece of foam in the cavity where the mirror mounting bolts are. It must be pulled out. The front mounting nut will take a 10mm ratchet end flexable wrench or a open end wrench. The bottom rear nut can be taken off with a 10mm deep well socket as well as the top rear nut.
A telescoping magnet:thumbsup: is handy to get the dropped nuts:mad2: out of the bottom of the door:agreed:
I used a vice grip bar clamp to hold the new mirror while i get the bottom 2 nuts started. They have to be started before the brace and top nut are put on. I reused one of the old nuts on the top stud. The new ones are very difficult to get started on the stud.
The foam will need to be trimmed to fit back in because of the long stud and brace piece. I followed a contour on the back side to to trim.
The plastic fasteners that hold the door panel usually don't survive being removed. I bought all new at NAPA.It takes 10 per door. Another thing to look for before putting the door panel back on is the 2 steel clips that go on the top of the panel to attach it to the window slot. Both on one door and one on the other were stuck on the door not the panel where they should be.
The top of the door panel goes in the window slot after fishing the gray window/ lock panel through. Starting with the top fastener, line up with the holes in the door and hit with hand to drive the fastener in. Same thing for switch panel.
There you have it. Great rear view visibility.
