chevyCowboy
So im finnaly going to stuff the new pistons into there new homes tomorrow.
i have some questions
where are the ring gaps supposed to line up at?
what is the spec on the ring gaps?
i need to also check the rod bearing cleances with plastigauge, is this done after all the pistons are installed or should it be done as they are put in? will it seems to me that it will be hard to check them with all the pistons installed and unlubed wont beable to turn the crank???? help? im confused on this
any other important info that you fellas with more experince than me can offer would be greatly appreciated.
thanks guys
thanks guys
