RayMich
I need to install an Auxiliary battery in our Snow Plow truck.
It is a 2002 Silverado 2500HD with 6.0L gas engine.
The guy that owned the truck before us had cobbled a second battery on the RH side but it is really a jury rigged install that did not work at all, so I decided to re-do the installation with factory parts.
I went to my local Chevy dealer and bought the OEM RH battery tray, bolts and brackets as well as two new DieHard batteries and the OEM battery cables. But I think I am missing a Battery-to-Battery cable.
I tried looking up pictures in my 2006 Service Manuals, but I can't find anything that shows how the cables must be routed and I can't see a Battery-to-Battery cable in the schematic.
The cable Part Numbers I have are as follows:
15321207 - Long Negative Cable (46" long)
15321209 - Small Ground Cable (11.5" long)
15321212 - Long Dual Negative Cables (Heavy Gauge 32.5" long / Small Gauge Cable 36.5" long)
15372006 - Long Positive Cable (39" long)
Can someone let me know if there is another Battery-to-Battery cable that goes from Positive to Positive between batteries. Unless I have to reuse the existing positive cable for the OEM LH battery, I can't see where the auxiliary battery positive terminal gets hooked up to.
Does anyone know where I can find pictures showing how these cables should be routed?
Thanks in advance for the help.
