turbovanman
I has boost, :O)
I was looking around for a reasonably priced combo setup as most are in the $400+ range, someone mentioned this so I gave it a try. It has a gerotor style pump ala gas intank pumps, housed in a 10 micron prefilter housing then a 2 micron post filter. Its regulated to 11 psi via a return line to the tank. I checked it when I got her running, 11 psi KOEO, 14 psi engine running. My van has never run this good, I've been fighting hard starting cold and no starts hot and so far, this has fixed all the issues I had, plus its got more power, smoother etc. My 6.5 lift pump just couldn't do the job, it just couldn't pull the my witch's brew out of the tank.
I didn't need or want the cooler so they sold it to me for $150 plus shipping. You can get filters for around $40 for the pair. I took both units apart and removed the stock fittings, tapped for pipe threads and installed the fittings I wanted. Had to use a bit of heat to loosen the factory loctited fittings.
http://dirtyhookerdiesel.com/i-1490...onomy-universal-lift-pump-duramax-diesel.html
![Picture209_zpsd0b1a2f7.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture209_zpsd0b1a2f7.jpg)
![Picture213_zps8cac4df5.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture213_zps8cac4df5.jpg)
![Picture214_zps73abb28c.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture214_zps73abb28c.jpg)
![Picture215_zpse7f6037f.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture215_zpse7f6037f.jpg)
![Picture217_zps14c25c18.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture217_zps14c25c18.jpg)
![Picture208_zpsd6fb890c.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture208_zpsd6fb890c.jpg)
![Picture211_zpsafb5e984.jpg](http://i12.photobucket.com/albums/a228/turbovanman/Diesel%20van%20turbo%20install%20pics/Picture211_zpsafb5e984.jpg)
