Pepperidge
Member Advocate
Injectors...I was just reading about a coating process "Nickel Boron" a coating that is virtually indestructible. It has a Rockwell hardness of 78-82.
Wondering if we could start with injector tips bored over the thickness of the actual coating process or larger for 20 or 40 over injectors...then coat the injector tips through the nozzle bore and such...maybe preventing this premature wear...
thoughts?
thoughts?
