cub124
Half Moon Detroit #1
I just put my Bosch Marie nozzles in, popping at 2650-2700 psi. I swear the turbo whistles more now maybe because the engine tone is different.
Anyhow I know which injector is tapping, it was torqued correctly to 50 ft lbs. I don't notice the tap until the engine was warmed up and after my test drive I tore the injector out and tore it apart, cleaned and re assembled. But it still tapps!!
can someone also share their secrets on how to fix a leaky injector at the body? I have tried one awhile ago and didn't have luck (with my only instructions being to take it apart clean the machine seal and put it back together at 50 ft. lbs.
