Injector Nut Torque Spec?
JayTheCPA
Annapolis, MD
What is the (rough) torque spec for the nut that holds the metal fuel line to the injector? (And by the way, I did read the manual first and no dice, only a spec for the injector; then tried a search and got *way* too many results that did not help . . .).
Background: Finally tracked down a fuel leak to one of the injector’s, took a 19mm open ended to the fuel line retaining nut (or whatever the technical term is), snugged it down a bit, and fuel leak was cured. Is there a torque spec for the retention nut so I can make sure I am applying the right amount of elbow-grease, or am I over-thinking this and should simply let the success stand?
