Injector line questions
chevyCowboy
Springfield Nebraska
can any one tell me what order the injector lines go in comming off the pump? i have a ds4 with the lines on it to look at but i was told they are differnt.
also should i turn my pump up now or wait untill the motor is broke in an turn it up later
You should have labled them. Trial and error at this point. Don't bend them. They should fit with no effort. You can't turn up a ds4. It is electronically controlled. If you are reffering to the 93 in your sig with DB2 yeah now would probably be easier to do it with manifold off .
are they separate or still paired together? unfortunately ACE is right, trial and error. been there done that.:nonod: next time tags.
Looking at the ip from the rear of the engine: 1 oclock#7, 2oclock#2,4oclock#6, 5oclock #5, 7 oclock #4, 8 oclock #3, 10 oclock#1, 11 oclock #8
thanks barry thats what i was looking for i think iv got it right but i just wanted to make sure. ya i deffanatly should have tag them but this was my first time doing a rebuild and i learned alot of things the hard way :rolleyes5:hopefully next time will go better.
so turning the pump up a 1/2 a turn now will be ok with the fresh rebuild it sure will be easier than when its all toghether.
I don't tag them. They really only fit right one way and I have a cheat sheet for location on ip.
1/2 turn I would think is too much. I know the 6.2s we only go a 1/4 when Adding a turbo which is about equivilent to a 4911 stock.
