knh208
I bought a set of new Bosch injectors from RockAuto a while back and finally plan to install them. I dropped them off at the local shop this evening (Diesel Services Group) to have them pop tested at a cost of $58 for the set. They will call me with a report in the morning. When I get the numbers, my plan is to look at what the average number is and have them adjust the worst ones to match the average.
My question is this: How much pop pressure range should I allow? Is ±50 psi good? 20? 10? :???:
They want $29 for each one they open up and shim. So, with that in mind, I want to minimize the number that I have adjusted.
Ideally, they'll all be close out of their sealed packages, and I'll walk away with a piece of paper that gives me the peace of mind, knowing that they're not going to leak or be total garbage when I try to fire it up. Regardless, I really look forward to hearing a silky smooth idle. I bet the neighbors look forward to it even more!
Any advice would be appreciated.
Cheers,
Kevin :thumbsup:
Cheers,
Kevin :thumbsup:
