treegump
Romans 3:22-24
So...because my truck did not come with fog lights, and my rear backup lamps are pathetic, I'm installing new ones on switches. (Actually my backup lamps are going to be on with my OEM lights and also on a switch). I tried to use the same indicator light for both switches, but it ends up making my lights stay on continuously. Is there a way I can wire the indicator light up to both switches so that if either one of the switches are on, it'll let me know?
Thanks!
FYI - I have a power running from the battery to the switch to the lights - no neutral or ground. The ground is from the lights to the body.
Thanks!
