packratt
Active Member
Make sure you cut the valve off before filling with oil. :mad2::mad2:
Ran 3.5 qt out on the driveway before I caught it.
Now that sucks!!!! I have a 3/8 vacuum plug on the nipple and two spring clamps to put back on before filling. So far its been idiot proof. Hope it stays that way.
Seems easier just to use the drain plug? ANy other major benefit to the Fumoto?
OK I'll be the idiot... What in tarnation is a fumoto ? I would have said a restraunt in Japan...
QUOTE]Only benefit i see is for the sellerANy other major benefit to the Fumoto?[/
It's one of the first things I install. Two reasons: 1) Saves drain plug threads. No more tightening/loosening and the potential for overtorquing or stripping. Also, no more drips. 2) Simplified oil changes - flip a positive-lock lever, the valve opens and the oil flows out. Flip it back to lock, and the valve closes. No possibility of the valve accidentally coming open. Simple, quick, reliable.Seems easier just to use the drain plug? Any other major benefit to the Fumoto?
So I could run a hose right from my Fumoto into the sewer drain my truck now parks on top of?...Joking of course...
half the fun of the oil change is grabbing that hot bolt without dropping it into the pan and making a mess!
