diesel on
Started it up in morning(65*) . It idled fine, noticed coolant light on, while engine was running (maybe 1 minute or less) opened coolant overflow tank to add coolant. It revved up on its own, then died. I finished adding coolant, went to restart it, same issue. Revved to 2500rpm, then died. I tried it on last time, same thing, rev up and die. (I suspected PMD)
ran lift pump and drained out some fuel(veggie oil), had a ton of visible water)
Flushed fuel lines with clean diesel, running straight diesel now.
issues now: no more idle surge(for now) I can drive it around block, no surging.
makes white/grey smoke at idle, loopy idle, like its running on only a few cylinders, It did sound like it was missing before I ran diesel through the engine. would happen around 1500-2000 i would hear it miss a little
changed fuel filter and purged air.
cracked one injector at a time, changed idle on the 5 i can get easily, need to do 3 passenger side , by turbo.
It does sound like the engine has a knock. or noise fro the pass. side of engine
Been that way since I bought it. It had a broken starter when I purchased it, so i did not hear it run.....
I drove it 50 miles previous day, no engine issues at all, had it towed home due to blown tire and it sat for a few days, fixed tire, now it has become a hot mess.
Did the tow home move/slosh some crap in the tank and clog up ip or injectors?
I did not see unusual temp readings on the day I drove it, just noticed coolant light the next time I started it( maybe a week of sitting.)
2. 1995 6.5 TD
3. 402,300
4. Indicate the model number on the Injection pump (starts DS4 or DB2......).
5. 2500
6. Yes, EGR
7. Air Filter was changed post-issue
8. Fuel filter was changed post-issue
9. PMD remote over intake, with home made heat sink
9a. looks homemade
9b. FSD/IP grounding wire is visable and attches to heat sink
10. Outside Temperature (C or F). 65°
11. Service Engine Light while running?- intermittent
11a. Service Engine light does glow during start/cranking/bulb check: Yes
12.Have you scanned for engine codes? No, obd1, don’t have the correct tool
12a. List exact results on engine codes.
13. Condition of Battery terminals cleaned and tightened
14. Newish, noth hold a charge of 12.5, engine cranks good.
14a. Are batteries a matched set of same age? yes
15. Condition of Major Grounds (removed, cleaned and tightened), two on block, one small wire (8 gage) for body ground.
15a Have the batteries been individually load tested? no
16. Does engine crank, or "turn over"? yes
16a. Does engine start and run? yes
17. If engine does not start- Crack injector line: do you have fuel? Yes/No
18. Does your Wait To Start light come on? Yes, glow plug manual
18a.Number of seconds WTS light is lit.
19. Engine Cranking speed (if you have an accurate tachometer). Don’t know
20. Are you experiencing Stalling?,yes, after idle surge
20a. Describe the event (upon startup only, down the road, hit a bump, etc...) after running for a few seconds, idle surges up to 2,500, then dies
20b. Do you notice loss of dash or instruments? No, fuel gauge is bouncing around, loose ground
21. Check turbo inlet and air filter for obstructions. None.
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?
23. Lift pump test - Describe results. Aftermarket unit, pumps 15 psi to filter, flows about a pint in 30 seconds. Truck was running ambient temp veggie oil only when I tested rate, now flushed with diesel, flows a bit more
24. Upon cold start, does the radiator hose get hard quickly? No, not noticed
25. Upon cold start, do you have excessive white smoke? No, but more than before when run on veggie
26. Do you have excessive cranking time before the engine starts?No
27. Have you used the block heater? Does it affect engine starting? Injector pump has heat block to heat veggie oil, runs for 2.5 minutes, then engine starts ok.
28. Are all glow plugs in proper working order? Appear to be so
29. During hard acceleration, do you have excessive black smoke? Not excessive
30. Do you have any unusual exhaust smoke issues? Was black/light grey when run on veggie, now appears white/grey while slowly driving around on diesel
31. Turbo check out - Pass/Fail
32. Indicate fuel that you are using: SVO/WVO
32a. If running Veggie Oil fuel setup, indicate details of your conversion, homemade wvo setup. Has ip heater block set up to heat oil, aftermarket lift pump, 5 micro hi temp filter pre-oem filter, fuel pressure gauges at 1st and second filter, heater plate inline of fuel with coolant to get oil hot once car is warm.
33. Are you using any fuel additives? no.
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? Don’t notice any
35. Do you have any service history available that might pertain to the problem you are having? no
36. Please indicate any modifications to the vehicle that might help us diagnose better.
Veggie oil conversion, single tank system, equipped with two lights on tells when oil in ip is 120*, second when oil is 150*, car will start at 120* easily, use manual glow plug for 10 seconds, then fires up. Truck has been run for 60k this way.
Pmd relocated on intake with custom heatsink.
2. 1995 6.5 TD
3. 402,300
5. 2500
6. Yes, EGR
9a. looks homemade
