nealpellecchia
Active Member
I want to send the heavy battery + wire right to the M terminal on the existing solenoid if I can fit the line on to the M terminal safely. The existing solenoid works the Bendix just fine, The contacts are just about gone so I will give that job to the ford solenoid. Every other wiring diagram that I have seen using the ford solenoid sens the + to the B terminal with a little wire to jolt the S terminal. They are still using the existing contacts. Can anyone tell me why this won't work or is dangerous? Also the starter key when engaged will activate both solenoids at once like they do but mine could be a little delayed because of the distance from the motor of the + circuit.
