Problem Child
Non Diesel mechanic
I just finished redoing my valve covers and of course I had to remove the fuel lines.Do I need to pull the glow plugs and turn over the engine to get the air out of the lines??
That is exactly what I do except I go WOT.When I've done mine, I'll leave the injector line nuts loose on the left bank. Once I'm ready to start it, crank it over until you see fuel. Tighten the injector line nuts, then fire it up. It should fire right up and smooth out in a few seconds.
I never touch the accelerator, many mechanical pumps go to a full fuel condition at startup by default. Electronic pumps?, I don't know for sure.
You can leave just one lose, it will do the job. The key is to have an escape for the air on the pressure side of the system to allow the injection pump to prime. Once primed and the majority of the air is out of the IP, fuel will purge the injection lines of air very quickly.
