I found this and found that my optimiser might be 18.1 amongst other info.
robzombie4551
robzombie4551
land of the lost. TAKE YOUR COUNTRY BACK
Specifications
Engine RPO Codes: LH6 ('C' series, with EGR) and LL4 ('J' series)
Displacement: 6.2L / 379 cu in
Bore x Stroke: 3.98 × 3.80 in (101 × 97 mm)
Block / Head: Cast iron / Cast iron
Aspiration: Natural
Valvetrain: OHV 2-V
Compression: 21.5:1
Injection: Indirect
Horsepower / Torque (at start): 130 hp (97 kW) @ 3,600 rpm / 240 lb·ft (325 N·m) @ 2,000 rpm
Horsepower / Torque (at final): 143 hp (107 kW) @ 3,600 rpm / 257 lb·ft (348 N·m) @ 2,000 rpm
Horsepower / Torque (army): 165 hp (123 kW) @ 3,600 rpm / 330 lb·ft (447 N·m) @ 2,100 rpm
Max RPMs: 3,600
Idle RPMs: 650 + or - 25
6.5L
The 6.5 L (395 cu in) version was introduced in 1992 to replace the 6.2. Most 6.5s are equipped with a turbo. This engine was never meant to be a power and torque competitor with Ford/International and Dodge/Cummins, but rather a simple designed workhorse engine that made credible power, achieved decent fuel economy and met emissions standards in half-ton trucks. The Duramax 6600 replaced the 6.5 in light trucks beginning in 2001 and the C3500HD medium duty cab and chassis (replaced by C4500 Kodiak/Topkick) and vans beginning in 2003, but the 6.5 (6500 Optimizer) is still produced by AM General for the HMMWV.
There are several GM 6.5 liter diesel engine production options. The Turbocharged L56, (VIN "S") was used in most 1/2 ton (1500) and light duty 3/4 ton (2500) trucks. One percent of the 1/2 ton (1500) contained an naturally aspirated version of the 6.5. Heavy duty 3/4 ton and 1 ton trucks used the Turbocharged L65 (VIN "F") engine. The L56 is emissions controlled with EGR and catalytic converters. The L65 engine has no EGR, and has no catalytic converter. There is a soot trap on L65 engines that is often mistaken for a catalytic converter. The L49 (VIN "P") and L57 are both naturally aspirated engines. L57 is listed as HO or Heavy Duty. Additional RPO codes are LQM (175HP) and LQN (190HP).
Changes were made by GM to the 6.5 in their light trucks for emissions or reliability improvement. The 1992-1993 model years used a 6.5-specific Stanadyne DB-2 mechanical injection pump. GM replaced the DB-2 with the electronic throttle DS-4 in 1994-2000 vehicles. In mid-1996 GM implemented a redesigned engine cooling system incorporating twin non bypass-blocking thermostats and a 130 GPM water pump. This improved the flow through the block by 70-75% and flow to the radiator 7%.
Applications
1994 - 1999 Chevy Blazer/ 2-door Tahoe / GMC Yukon
1992 - 1999 Chevrolet Suburban / GMC Suburban
1992 - 1999 Chevrolet and GMC C/K
2000 Chevrolet and GMC C/K 2500 & 3500
2001 Chevrolet and GMC C/K 3500
1994 - 2004 AM General Hummer H1
1994–present AM General HMMWV
Specifications
Engine RPO Codes: L49, L56, L57, L65, LQM, and LQN.
Displacement: 6.5L / 397 cu in
Bore x Stroke: 4.06 x 3.82 (in.)
Aspiration: Turbocharged (Borg-Warner GM-X series) Also available naturally aspirated.
Valvetrain: OHV 2-V
Compression: GM Early 21.3:1, GM Late 20.3:1, AMG/GEP Marine 18:1
Injection: Indirect
Power / Torque (lowest): 180 hp (134 kW) @ 3,400 rpm / 360 lb·ft (488 N·m) @ 1,700 rpm
Power / Torque (highest): 215 hp (160 kW) @ 3,200 rpm / 440 lb·ft (597 N·m) @ 1,800 rpm
Max RPMs: 3,400
Common problems
Main Bearing Web Crack: In both 6.2L and 6.5L engines this is reportedly fixed with a combination of improved higher nickel cast iron alloy and lower block re-design including, but not limited to, a main bearing girdle. These features are in the new for 2007 AM General GEP P400 6500 Optimizer enhanced 6.5L diesel presently being sold to the US Government for the 6 ton armored HMMWV.[1]
Crank Failure: Related to age failures of the harmonic balancer, the vibration damped accessory drive pulley, or the dual mass flywheel.
Pump Mounted Driver: Relates to thermal failures. The PMD is screwed to the DS-4 injection pump on the 1994-2001 GM 6.5 diesel utilizing fuel flow to dissipate heat. The injection pump is mounted in the intake valley (a high heat area). The PMD contains two power transistors that should be cooled by proper contact with the injection pump body. If the pump is not precisely machined to make complete contact with the transistors via the silicone thermal gasket and paste, the PMD is improperly installed without the gasket or paste, the PMD is installed off center with the pump body, or corrosion develops on the mounting surface the PMD will overheat. Several companies manufacture an extension harness and heat-sink kits. These allow an owner or their mechanic to relocate the PMD away from the injection pump to a lower heat environment and/or a place that can get more air flow.
Fuel system
The fuel system on both of these engines relies on a very basic setup. On the 6.2L engines, a camshaft driven mechanical lift pump draws fuel from the tank to the injection pump (also camshaft driven). On 6.5L engines, the lift pump is electrically powered. The injection pump delivers fuel precisely as the injectors need to fire correctly. The fuel system uses Indirect injection and, on 1982-1993 engines, is completely mechanical, much like the Ford 6.9 & 7.3 International Harvester IDI fuel system utilizes. The 1994+ system is similar, but uses the electronically controlled Stanadyne DS4831 series of injection pumps instead of the mechanical DB2831 series found on 1992-1993 6.5's and the DB2829 found on 6.2's.
Optimizers cam in both 20:1 and 18:1 variants.
http://www.optimizer6500.com/default.asp?section=specifications
18:1 was intended for marine use as indicated on the above linked page.
If you're got a "Teds" engine it's going to most likely be a 20:1 since they were "surplus".
GM replacement Optimizers are 20:1 also.
It's possible your's could be 18:1, but very unlikely.
Still, nothing wrong with a 20:1 optimizer though.....
