ak diesel driver
6.5 driver
So a few weeks ago I fished these rubbery strips out of the bottom heat duct, everything seemed to still be working normally. This morning it was -3f and I could tell the heater was not putting out it's normal amount of heat for these temps. I can only assume the gasket is from the heat blend door and it's letting in to much fresh air. I called the dealer and they said item is discontinued and no dealers anywhwere have it in stock. I checked LMC and the only thing I could find is item #16. Is this the right part? Also do I have to remove the entire HVAC box to replace? Any other sources for parts?
