I took my fan out to see if I could oil it. It has been making a lot of noise since the cold weather. When I got the fan out the blades were dirty and so was the motor where you could see in the vent tube hole. Blew the motor out, washed the fan blades, oiled the motor and reinstalled. Here is the question I have. When I hooked the power wire back up the fan I decided to run the fan. On low the motor didn't turn at all. I was looking into the vent hole and could see the the windings. On the other 3 speeds the fan worked fine. So is the fan supposed to turn when on low? If so what could be the problem with mine?
