gahammerle
Saved by God's grace
I'm not getting the blower to work on any setting. When I turn the key to On and then turn the fan control on, the clutch on the AC compressor engages and disengages when I turn the fan off. The clutch engages whether the AC button is depressed or not - is that normal? The light does light up on the AC button when pressed.
Not sure if this is related or the cause - but last week I jumped a friends truck and the jumper cables were hooked in reverse on my battery (don't ask ) for a few seconds - burned my thumb yanking the cables off - those things heat up quick! I didn't drive the truck for a few days after that so I don't know if the blower was working after that mishap and quit working later - my wife drove the truck but doesn't remember when the blower worked last. I checked fuses in the fuse panel and under the hood and they look good. As far as I know, everything else electrical is working fine.
Any ideas?
Any ideas?
