Acesneights1
I was going to tag on one of the other LP threads but didn't want to Hijack.
The Burb started running like crap on the way home today (Yes I know it's a 6.2 but the info to follow will be of more interest to 6.5'ers). It was losing power badly on hills, smoking and felt like if you let off the throttle it would"Catch up".
A little history. I converted the Burb to a Factory 93 6.5TD Elec LP. This is supposed to be "The better" one.
So The burb felt like it was running out of fuel under load. I disconnected the fuel line from the FFM (I have the old square style) and threw it in a jug and turned the key on(NO OPS here). Fuel came out .
Hmm...Hooked a FP Gauge to the effluent side of the FFM. 5lbs at idle. The minute I put the truck in drive and touched the fuel it dropped to zero. Driving down the road under load(Climbing) it went into 10+ inches of vacuum.
Hmm...Here is where TD's wisdom comes in. The Pickup tube had rotted off in the tank so I took the unused bulkhead from the Lemon(Dodge) that came with the Raptor and made a new pickup. However there was no way to put a sock on it.
The aftermarket Pureflow (AIRDOG) Pickups are designed without them. I knew there was some rust floating around in there so I took a Glass Holley inline fuel filter from a gasser and put it in pre LP to grab any big crap.
TD warned me it may clog quickly. He was right. So I removed it and bypassed. Now the truck was running good again under load(so far) but now I noticed the LP pressure was still zero under acceleration except this time, it did not pull a vacuum.
At WOT it was zero. That makes me wonder, if my lowly 135hp DB2 driven 6.2 can pull the stock LP down to Zero at WOT how could this thing possibly feed a 6.5TD...Now the same reasoning that brought TD's FTB to life I had actually done years ago but on a 6.2
The 6.2's have a tiny little supply lline from FF to IP as well. ON that truck I did the experiment on it had the older 6.2 setup with the 2 spin ons. I elimiated the PIA seconday under the manifold , used a better fitting on the IP and ran straight to the primary and used a better spin on filter.
What has my noodle cooking now ...Is the 6.5 LP really that weak or is my 6.2 having starvtion issues due to small supply.
I find it hard to believe since the 6.2 is stock
What will really make this interesting is when I install(now I have the motivation) my nice new Autometer Full sweep on the CUCV which is runnig a 100GPH Raptor and see if the same thing happens..That will tell alot.
