jrsavoie
Recruit
Right Front axle removal 95 Tahoe
I'm getting ready to pull my right front axle to install new ball joints.
Do I need to remove it completely? Or just enough to get to the Ball joints?
The book is a little lacking on removing the axle.
It says to disconnect the tie rod and the stabilizer. Are these steps necessary?
Different book says to take the bottom of the shock loose. No problem there.
How does the axel fit up to the front pig?
Do you have to take it towards the center of the vehicle to remove it?
Any help or pics would be appreciated.
Doesn't seem all that hard but the instructions and pics are lacking a little,
Thanks
I've got 3 books out and still haven't figured it out.
I have the tie rod lose and the nut off the stabilizer link bolt. It's not hitting there.
I was going to remove the bearing assembly but the bolts are froze. Now I'm out of oxygen for my little torch. The big torch is mounted in a truck and and I either have to string out a couple of hundred foot of torch lead or move stuff and move the truck
Does the bearing assembly have to be out to remove the half shaft? It didn't say anything about that in any of the books.
What is the part called that the ball joints attach to? Steering knuckle?
It is possible that I may need that part anyway. The top ball joint was very sloppy but did not come loose when I loosened the castle nut. So I would imagine That part of unknown name - Steering knuckle? - is good.
Where is the best place to buy the part if I end up needing it?
I will definately need new bolts for the bearing assembly. "No never-seezing bastards got me on this one."
Thanks
