trouttrooper
Big Blocks ROCK!!!
Ok, so my new tow mirrors showed up and I figured I had all the knowledge I needed on how to remove the door panel. Apparently GM has a couple different ways they attached these darn panels, so here we go. I'll highlight the steps that were different from what I had read on other posts.
original mirrors, 2005 power towing mirrors
pop out the inside door lock.
pop out the triangle
remove 7mm screw above handle
remove 7mm screw on underside of door
remove Phillips head screw behind door latch <--- new one on me
little plastic/rubber cap, pop it off <--- new one on me
remove torx T20 screw underneath
