What are your thoughts on oil temps in a turbo motor under towing conditions....... the temp probe will be in the pan....
Conventional oil -----
Synthetic oil ------
General rule of thumb- oil should be within 20* of coolant temp.
Are you ceramic coating the precups? This would be a high heat loss area you would want to slow down IMO.
I suggest one of the oil cooler kits our vendors sell with different oil cooler hoses than the factory stuff.
