carguy13
Recruit
so I recently aquired a holset turbo off of a fedex truck was told it had a cummins not surehis which engine or what turbo because there is no id tag on the turbo but the turbo is set at 30 psi of boost and looks to be a hx35 or similar turbo not sure. My problem is how do I get the boost down to a safe level? My other thought is can i just run twin turbos and run my factory turbo off the compressed air produced by the holset? In my head that would eliminate back pressure from the factory turbo and give you a cooler air charge and be cooler because you have twin turbos. Please give me some feedback on this either how to get the boost down or the twin turbo idea thanks for your input.
