hit a deer
DEERE3594
I welcome everyone...not just Penguins!
NE Ohio
Deere hit a deer tongiht. just got in. have to be to work in 2 hours. im in need a sleep. i please forgive me, but i dont have time to search. best place/vender to get oil cooler and lines? i shut it down and still had oil presure. i now have 2 none runnin 6.5s, i got to have one going. sorry for the very noob Q/post from a very non noob, forgive my speeling mistakes :skep:
hey bro, i put the lubrication specialist kit on mine. took very little time to install it. ive also heard that the pmdcable kit is pretty nice too
For a quick cheap fix, cut the rubber lines and join them together with a plumbing fitting of the correct size....it is winter after all.....
Sorry for the shitty night Justin,deer and trucks don't mix very well.
Like Chris said,2 5/8 pipe elbows ,1 or 2" pipe and 2 hose barbs will do just fine
Wow, deere hit a deer. Sorry to hear. Been there. Sounds like you have my luck.
:suicide:
What kind of grill do you have the composite or W/T Headlights ?
Also you could take the grill etc off the other truck. It takes about 10 mins to swap a grill.
Sorry about the bad luck there Justin, what's wrong with this other one ?, since you have 2, is it possible to take parts you need off the worst one and get one of the 2 up & running? Don't be a stranger you have my # as well as some others on the site if you need to talk over some ideas how to get back up & running.
Tim
my 94 needs a starter, and is drinking coolent like its its job. it also needs a hub i think and a caliper is locked up. the oil cooler lines leak like hell on it.
red one now needs the oil cooler, PS cooler, maybe a trans cooler, grill is ok, its broke but it will work. i have lights to replace the broken ones.
if anyone wants to buy either or shoot me a offer, im looking at a 2001 tahoe :eek:
thank you guys for all the replys. its been a long week. had a spindle snap on a 16 batwing deck going down the road and rolled it over... ah
givemebeer :hihi:
Hang in there Justin. By now you know these things pass in time. All your friends are still here for you, as I'm sure you know...
In my searching I found that the pex hose barbs seemed to be the best fit. On a Christmas eve emergency about 4 years ago
Or they may have been the best fit I had on hand
givemebeer :hihi:
if you are in SUV mode check these puppies out:
http://www.thetruckstop.us/forum/showthread.php?26066-2-diesel-suburban-4wds-94-amp-95-on-an-auction
i do have a tranny cooler, but I am at college and IDK when I anm Headed back. hopefully this weekend. It is probably off a 99 C3500 2wd Dually (I got a ton of parts from a guy, and it came from no less than 3 GM 6.x diesel trucks, so 99 is an assumption. it may have came from a 95 K2500 also) If it turns out yours did get smooshed, PM me and we will see if we can work something out.
also, what all got effed in the accident? I may have some stuff, not much, but some.
Justin I have a cooler for you....It's got a couple fins that are tweeked and a little bow to it....(nothing to bad)....When I wrecked my rig I bought a used rad support with the coolers, otherwise I would have used mine.
Just PM me an address and I'll get it out to you....
