I replaced door hinge pins and worn bushings. Easiest way to do it, I think, is to use engine hoist. I lifted the door up just so much to take the load of from the hinge.
I used a shield between door and fender.
First I removed the spring, then pins and the bushings. Installed new bushings, applied grease between hinges and put new pins.
Hardest part is to put the spring back. I put the spring in a benchwise and used ties to hold it down.
