It is time to take a new direction in 6.5 performance. Conventional thinking is a diesel has lots of torque in the low end so if you ever do a converter it should be tighter than factory. This would be true if I had the factory turbo spooling up in the bottom end. I already know the factory setup sucks as the auto trans shifts you to high RPM where the small turbo chokes. Conventional thinking does not apply to the underpowered 6.5 vs. other diesels anyway.
On a brake stand I get 1600 RPM with my setup. It is sluggish with the AC on, cooling fan load, and high outside temps. Once the RPM gets up it really takes off. Even the 1993 suffers from this some from a dead stop.
http://www.thetruckstop.us/forum/showthread.php?39789-ATT-videos
So at this point with a trans overhaul needed it is time to let the engine slip up to the higher RPM with a high stall converter. When it gets to the higher RPM locking the TCC at WOT to load the engine is part of the plan usually starting in 2nd or 3rd gear. The TCC lock should keep the MPG in line with the higher stall. It is possible getting up to speed may improve MPG via less smoke. I figure 500-1000 RPM over stock stall should get me in the ballpark.
