JeffsJeep04
Anyone know of some semi-easy to get ahold of switches that will look factory-ish, or better then some exposed toggles? I'd like to put two switches in (preferably below the cargo light switch). I have the push button 4x4, so that spot is out. Also, is there anywhere other then the GM dealer to get the pins? I know it's not great on the engine to sit at low idle for extended periods of time, and that big hunk of iron takes a LONG time to warm up when it's -10° out
