DennisG01
Now that the cold weather is here, I've got a little fishbite thing going on.  When warming up the truck, with either of the high-idle's engaged, the engine will fishbite for about 1 or 2 minutes (might happen about 20 times within that 2 minutes).  If don't engage the high idle, it will not happen.  This only happens if the truck has been sitting long enough to get good and cold.
I just wanted to pick your guys' (and gals' :smile5
 brain a bit.  My thought is probably a bad ground issue or the connection into the ECM.  Does that sound right?
Also, does this fishbiting hurt anything? It's a split-second each time it happens.
