dmaxfireman
'Can Do' kindof Guy
I was a huge fan of the all-on mod with the diodes between relays. It always worked like a champ until I put my 55w hids in. Now if I go from lows/fogs to high(all-on) then back to lows/fogs the fogs go out but the switch still says they're on. All polarities are correct on ballasts. Could the diodes I used not be protecting from reverse voltage or not able to hand the higher starting amperage of the hid's???
issed:issed:issed:I always like my truck to work perfectly and I'm starting to get annoyed with it
