HID Problems
Big T
Fullerton, CA
Here's what my headlights look like currently:
Hard to see, but the driver's side bulb is pinkish/purple.
Here's how they shine against the garage door:
You can clearly see the pink/purple beam for the driver's side. Not sure what's causing this but it looks like it's coming from the bulb which is a 4000 color and bought from MadMax here. Also, the beams are just spots and do not spread the light very well. The prior housings recommended by Matuva here did a better job. The main difference between the two housings is that the mirrors in the newer ones have horizontal hatch lines in addition to vertical lines, whereas the older housing mirrors only had the vertical hatch lines.
