here is a script i made to use the lbz air cleaner
stacks04
McLovin
terryville ct
simple script with the applied changes that gm made to the stock tune to correct an overheat condition. WARNING: DO NOT USE THIS UNLESS YOU HAVE CHANGED YOUR AIR CLEANER TO THE LBZ, ROUND FILTER STYLE. I AM PUTTING THIS UP HERE FOR THOSE THAT WANT TO MAKE THE UPGRADE BUT DON'T WANT TO HAVE TO GO TO THE DEALER.
  • lbz_maf_update.txt
here is one for lb7 idle in an lly vvt truck. also includes egr off provisions. keep that nasty soot out of your engine:)
  • lb7_idletune.txt
