Heres the story -on the way to work @80mph I slow down for sun pass toll to 35mph then go to accelerate and @55mph or so the truck dies(running on WVO)
Pull over to nearest right-a-way and purge to diesel while trying to starting truck(normally takes 20 sec then starts up) - nothing.
Threw a bottle of water on PMD still nothing and continue every 5-6min and it did not start.
-There were some fishbites on the way up and my wvo fuel quality has been good.
codes were 29 32 33 42 44 45 49 78 84 81 92
then 44 45 only came up
-Fuel pressure gauge shows 6psi on both fuels
-I deleted vac pump, homemade turbo master max 10psi,
-wastegate solenoids deleted
I'm getting the batteries charged and will check for fuel @ injectors. And run thru the checklist when back in. THANKS ALL
