Chief915
915A Maint Tech
All, I have searched the forum and "think" I am doing these processes correctly, but I am coming up with odd results. Let me know if I am missing something here.
This is the thread that I am going by.... post #2 http://www.thetruckstop.us/forum/showthread.php?11754-FYI-TDCO-Timing-the-DS4-Injection-Pump
94 Suburban, "F" engine, 5068 IP with stock BMSD chip, new Bosch injectors, and I am using GMTD scan tech.
Here is a snapshot of before I touched anything.
__________________________________________________________________
ENGINE SENSORS
Engine run time: 00:13:02
Boost pressure (MAP): 14.4 PSI
Desired EGR: 15.23 PSI
Desired idle: 600 RPM
EGR pressure: 15.01 PSI
EGR duty cycle: 0 %
Engine coolant temp: 186.4 F°
Engine speed: 581 RPM
Glow plug relay feedback: 0.1 Volts
Glow plug voltage: 0.1 Volts
Ignition voltage: 13.2 Volts
Wastegate duty cycle: 67.2 %
INFORMATION SENSORS
PCM Calibration ID: 145
Current DTCs: 0
Accel. ped. pos. 1: 0.67 Volts
Accel. ped. pos. 2: 4.41 Volts
Accel. ped. pos. 3: 4.02 Volts
Barometric pressure (BARO): 14.15 PSI
Battery voltage: 13.3 Volts
Fuel temperature: 104.7 F°
Intake air temp: 96 F°
Throttle position: 0 %
Turbo boost (Calculated): 0.25 PSI
Voltage reference sensor: 1.3 Volts
INJECTION PUMP SENSORS
Actual injection pump timing: 25.78 Deg °
Cam reference missed: 0 Counts
Crank reference missed: 0 Counts
Fuel calibration: 125 Counts
Fuel rate: 9.38 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 9.38 mm³
Fuel rate - Maximum transient: 35 mm³
Fuel rate - Throttle requested: 0 mm³
Injection pulse width: 2.22 ms
Injection timing - Measured: 4.4 Deg °
Injection timing - Desired: 4.4 Deg °
TDC offset: -0.35 Deg °
Now, I have read on various posts that when you command "time set" or "tdc learn" the engine could/would/should stumble, change sounds, etc while the processes are running.... Is that correct? I commanded "time set" on mine and the rpm/sound/smoothness of the engine didn't change at all, almost like nothing was happening at all.
I got under the hood and rotated the IP toward the driver's side slightly. I commanded "time set" and "tdc learn" again...still no changes in engine noise or smoothness at all during the process. TDCO changed to -2.02 and set code 88.
I got under the hood again and rotated the IP back to the passanger side maybe half the width of the scribe mark, barley enough to see it move and cleared the code. Started it again and immediately got actual and desired timing of 4.5. I commanded "time set" and TDC learn, .... again no rpm change or audible change in the way the engine ran at all, either during time set or during tdc learn. No codes after it was finished.
Right now, this snapshot is where I am sitting.
ENGINE SENSORS
Engine run time: 00:19:50
Boost pressure (MAP): 14.6 PSI
EGR duty cycle: 0 %
Engine coolant temp: 188.2 F°
Ignition voltage: 13.6 Volts
INFORMATION SENSORS
Current DTCs: 0
Accel. ped. pos. 1: 0.69 Volts
Battery voltage: 13.6 Volts
Fuel temperature: 98.2 F°
Intake air temp: 87.6 F°
Turbo boost (Calculated): 0.45 PSI
Actual injection pump timing: 26.93 Deg °
Fuel calibration: 135 Counts
Fuel rate: 7.5 mm³
Fuel rate - Idle: 7.19 mm³
Injection pulse width: 2.21 ms
Injection timing - Measured: 4.3 Deg °
TDC offset: -1.94 Deg °
Does it sound like I am doing the procedures correctly or am I missing something? Does the data look/sound normal? Is it normal that the engine sound doesn't change at all when I command "time set" or "tdc learn"....even after moving the IP? Where I am sitting right now, is that really close to "ideal", should I stop messing with it and be happy with where it is? Does this indicate anything is worn out (IP, timing chain, etc)?
I thought I read somewhere that you want actual timing around 8 to 8.5, and TDCO at -1.94 for a best case senerio.... mine timing is 4.5 and TDCO is -1.94.... how do I get the timing to advance without changing the TDCO? Will I "see" actual timing of 8.5 on my data or will it show 4.5 on the screen, but actually be 8.5 because of the new TDCO? The article I referenced at the beginning kinda confused me on these questions.....
Thanks in advance.
ENGINE SENSORS
EGR duty cycle: 0 %
INFORMATION SENSORS
Current DTCs: 0
Fuel rate: 9.38 mm³
ENGINE SENSORS
EGR duty cycle: 0 %
INFORMATION SENSORS
Current DTCs: 0
Fuel rate: 7.5 mm³
Thanks in advance.
