I have a 02 with with everything listed below still being used on my truck. The problem is at highway speed or almost anything above 2000 RPM the truck cuts out like it quits getting fuel for a split second and will continue to burp till i let off the the pedal. some time it will repeat if i give it gas some times it will work like it is supposed to. This started after I picked up my new 5th wheel trailer. It has bin random and is starting to happen more often. I have changed the fuel filter and taken the truck back to its stock tune ( removed both the chip and the programmer) Nether of which have changed the way the truck is cutting out. If you read if there is any codes being set it says that there is undetected codes set which will say it 3 or 4 times. Is there a throttle positioning switch that could going bad??? Or injection pump??? Any help would be great.
Thanks
I have bin stacked with the triple dog and edge for awhile now not with the predator like it says below.
__________________
Thanks
__________________
