Kap270
Fellas, I need some help with my 94' K2500 6.5td Suburban. This morning when I went to start it I turned the key, waited for the glow plugs to heat up, then tried to start. I heard two clicks and completely lost electrical power. No dash lights, no radio, no climate control, and the headlights had no power either. Even the engine bay light on the bottom of the hood wasn't on. Periodically I get power back, but the same thing happens again. I cleaned the battery terminals and checked and cleaned ground connections, and everything has 12.4v. None of the fuses are blown in the internal fuse box and I replaced the two 30A ignition fuses. Anyone have ideas, I'm pretty lost.
