matuva
Tropical 6.5er
I was looking a the torque thread and found following values :
Crankshaft:
This is not clear for me. Which ones are the 12mm outer bolts, the inner, and the 10mm outer bolts
Wich ones are the ones for the connecting rods and for the bearings on block ?
You may say I should find when the oil pan will be down, but I waan a get sure I get all torque informations before I swap the crankshaft.
Thanks for your help...
Crankshaft:
Bearing Cap 12mm Inner Bolts:
Make Two Passes--55 (75)
Final Pass--90* more
- Bearing Cap 12mm Outer Bolts:
Make Two Passes--48 (65)
- Bearing Cap 10mm Outer Bolts:
Single Pass--30 (40)
