cwq21
I have an anti-freeze leak somewhere on the front lower half of the engine on the drivers’ side. I took off the skid plates and checked it when I got home from camping. It’s dripping (pretty good) from the drivers’ side above where the bottom hose connects to the water pump and not behind the pulley that I can see. There is a flange that connects to about a 1 1/4” tube running to the rear of the drivers’ side of the motor with a gasket right above where the bottom hose connects also and I can’t tell if it’s coming from there or not.
Could my water pump be leaking or is it something else?
Any ideas?
Any ideas?
