TANK'S 250
Black Ops Bumpers
- Messages
- 655
- Reaction score
- 0
I've seen alot of people asking about trailer tires over the years, load ratings, best tire, etc, etc, etc.
Here's some of the info I've compiled, and a awesome supplier.
www.easternmarine.com have load ranges all the way up to "H" 6,005lbs.
Here's a link to some normal size, heavy load tires.
When considering a trailer tire, here are a few important things to look at.
TIRE CONSTRUCTION TYPE - Bias Ply vs. Radial
TIRE APPLICATION TYPE - (ST) Special Trailer vs. (LT) Trailer
TIRE SIZE - % of section height / section width Refereed to as 'Aspect Ratio'
TIRE LOAD RANGE - Load carrying capacity and air pressure rating
::::NOTES:::
Inflation
Always inflate trailer tires to the maximum inflation indicated on the sidewall.
Check inflation when the tires are cool and have not been exposed to the sun.
If the tires are hot to the touch from operation, add three psi to the max inflation.
Underinflation is the number one cause of trailer tire failure.
Load Capacity:
The combined capacity of all of the tires should exceed the loaded trailer weight(GVWR) by 20 percent.
Speed
All "ST" & "LT" tires have a maximum speed rating of 65 mph.
Time
In approximately three years, roughly one-third of the tire's strength is gone.
Three to five years is the projected life of a normal trailer tire.
It is suggested that trailer tires be replaced after three to four years of service regardless of tread depth or tire appearance.
Mileage
Trailer tires are not designed to wear out.
The mileage expectation of a trailer tire is 5,000 to 12,000 miles.
These 'Special Trailer' (ST) tires have been constructed for better high speed durability and bruise resistance under heavy loads. Trailer tire construction varies substantially from automotive tires, therefore it is essential to choose the correct tire for your towing application. In general, trailer tires have the same load range (or ply) from bead to bead and are bias ply construction. This allows for a stiffer side wall which provides safer towing by helping to reduce trailer sway problems.The use of (LT) tires offer a wide range of specialized trailer tires for heavy loads on average sized wheels. LT doesn't not mean "light truck".
The use of 'Passenger Car' (P) is not recommended for towing because their construction, they normally do not have the sidewall plys, or weight rating sufficient for trailering,...usually radial or bias belted, allows for more flexible side walls. Using a "P" tire could lead to increased trailer sway and loss of control.
::::NOTES:::
Inflation
Load Capacity:
Speed
Time
Mileage
