Detroit Dan
Anyone know if there is an available headlight switch that is more heavy duty than OEM? I have a 97 and am currently getting ready to replace yet another bad switch. What happens is the one little tiny wire going into the back of it gets hot, melts away some insulation and loosens up where it goes into the back of the plug. Someone told me they thought there was an HD replacement available, but I couldn't find it at the parts store or online. Parts counter guy suggested I put in a relay, but I'm not sure how, I've never had any luck with relays. I'm kind of an idiot when it comes to wiring. I have a soldering iron and wire strippers and a fire extinguisher, but I really need someone to hold my hand and walk me through things like that ;>
My problem is I have a dually that came stock with 5 clearance lights on the cab, 7 clearance lights on the dually fenders and tailgate, in addition to which I have added a lightbar that contains a full set of taillights and marker lights, which is essentially like having a trailer hooked up. When I do have a trailer hooked up that's another pair of taillights and a few more marker lights. This overloads my headlight switch and leads to premature failure. Oh, and I also have the all4onhigh headlight mod with Sylvania Ultras.
So, if there's no easy fix for the switch with a HD replacement, could somebody make it simple for me as to where and how to put a relay in?
Also, I just ordered an HID harness and light conversion kit for the lowbeams (at Nicks suggestion), so maybe that will help a little, I'll probably do the same to the high beams later. Even with all 4 headlights HID with new harnesses, I think I am probably asking too much of a stock switch just based on the number of running lights I have. I did try LED bulbs but the couple sets I tried were unimpressive, and I don't want to spend more money right now in that direction, the really good ones are too expensive.
Thanks for your input.
