Heater Stuck blowing cold
aggar
Don't tear it up!
Kirklin, In
Help! Heater in the 01 is blowing cold no matter which way I turn the Temp knob. Which Actuator would it be??? There's 3 on there and I was just wondering what one to look at first?
Thanks.
Ryan
HVAC resister thats prone to failing? I went through that with my 04.
Not sure if it has the same controls as my 05, But mine starting blowing hot in the A/C mode after disconnecting the batteries. I had to pull the HVAC fuse under the hood and then wait 10 sec. then replace it, turn the key to the on position and wait 1 min. with out cranking or turning anything on. This worked on mine. Hope it helps.
