Heater core quick release fitting - Need Barb Info
Matt Bachand
Depends on the 6.5
Worcester, MA
Going to order my 1 piece 3/8ths barbed T for FTB,
And figure I'll get the fitting to replace the Quick release too. Last time I undidd that it weeped. HOpefully no issues.
I can't find the threads with this info though.
Can anyone tell me the size of barb to get so that it threads into the t-stat housing, and then I put 5/8 heater hose?
Thank you.
If I am not mistaken what you are talking about is the famous coolant crossover connector. You need 1/2" NPT tap to clean it out. You should be fine. The replacement that the store sell now is made out of steel instead of porous metal. Or you can use 1/2" NPT to 5/8" barb connector in place. GM has a part no. that actually have the orifice in it.
Quote from JMJNet.... Found it!
LOL I re-read it and it seems that way!
I think NPT and MIPS are the same....
for 3 bux I ordered one up along with my T Barb Fuel pressure gauge after I FTB.
I put a new napa quick connect on my 95LD. It leaked worse than the old one. Then I went to a pipe to hose nipple with the restriction like my 91 6.2 had on it. Napa#660-1732. No leaks now.
Some will swear that the restrictor is necessary, I have just a straight nipple on my burb & truck, possibly the restriction from 1/2" IPS to 5/8" barb is all restriction that is required for Southern USA.
Your hotter than me, so I'm not worried.
If my heater core blows out, then it was going to sooner or later, right? What better time than now...
x2
It was all I could get in a bind and I had plans to replace it with a proper nipple. That was over 2 yrs ago.:smile5:
I thought the idea of the restriction is to slow down the flow to the heater core so it has a chance to shed some heat. Too fast and the heat cant get out just the same as no thermostat. Or am I way off base?
And here I thought it had to do with balancing the flow from side to side.
I think you are referring to a restricting oraface that is on the waterpump itself?
If you decrease the size of the oraface, I'm not sure you are slowing down the coolant at all, just restriction how much goes through it. The pressure should remain the same?...
The restrictor just limits the coolant flow to the bypass . And push the heat to through the radiator to let the fan clutch work more efficiently by being able to sense the heat from the radiator rather than all the heat in the heads, and make a more stable heat management. Yes pressure is not affected.
