Head Gasket?
Clipper
San Diego, CA
My baby is starting a bit harder lately, takes 10-12 seconds of cranking when cold, 5-6 when hot.
Kicks 4,5,6 times during cranking, before it starts. Takes some throttle.
Used to be 2-3 seconds, started right up first kick. No throttle.
When cold, big cloud of white smoke.
When hot, if I shut it off for more than 2-3 minutes, big puff of white smoke on starting.
Runs pretty well otherwise, power normal, no smoke unless I'm stomping on it.
I am hoping against hope that it is not a head gasket...any ideas?
Thanks in advance...
That's no head gasket, it's fuel related. I'm fairly sure it's either a weak or faulty glowplug(s).
If it were headgasket you would have some of the following symptoms:
Hard upper rad hose on cold start, overheating, oil in coolant, coolant in oil, the smell of antifreeze in the exhaust, etc.
I wouldn't assume the worst. If it's not giving huge amounts of trouble I'd casually investigate it, rather than spending vast amounts of time/money on the situation.
Use all of your senses while troubleshooting just about anything. Smell the smoke and you'll know if anti-freeze, fuel, or oil is involved.
