monzajhon1968
Monzajhon1968
When changing head gaskets on 6.2/6.5 Should I change the head bolts? I am going to use the newer felpro head set its supposed to be the best head set. This engine has a banks kit on it also.
The idiot that thought up the TTY bolt scheme should be tarred and feathered.
MGW
SNIP....SLIGHTLY off topic, but aren't the main bolts TTY? The specs I see for them IIRC said so much torque, plus so many degrees.
ARP-130-4062 Not listed for 6.5. Summit racing $160. The tty bolts fail because of heat and poor material. Think of them as rubber bands.
You know, this was the EXACT question I asked one of the guys who works here at the local GM medium duty truck shop (lots of 6.2/6.5 work going through their shop).
The "indirect" answer I got was no, that they are not TTY on the mains, -but then and again, -WHY the funky TTY torque procedure? (the 90 degree part)
The guy I spoke with out in the shop responded to my question by telling me, (verbatim) -"in all the years I've worked here, we have never replaced a set of mainbolts on a 6.2 or a 6.5"
That really didn't answer my question though.
It sure makes one wonder, doesn't it?? :thinking:
