dka99burb
So, I assume that when changing the harmonic balancer we should change the front crank seal? If so, what is it called and what is the part number? I have some oil leaking from that area now and I plan to change the HB next week. It's not bad but I think it should be done while I am there.
Also, do I have to pull the radiator to pull the HB?
Thanks.
Thanks.
