matuva
Tropical 6.5er
Howdy all,
we're facing a problem with a 1997 K1500.
She is very difficult to start, does after several cranking, and when she starts, the idles is very rough, throwing a lot of black smoke.
If you let her idle, she will run very low, about 500 rpms or less, rough, and die.
You can rev it up a bit, always rough and smoking a lot, and as soon as you release accelerator she dies.
More than a month ago, she has been experiencing stalls previously, because of a dead PMD.
Being a bit short of money, he tried to keep running with a used PMD, with more or less luck.
While she was experiencing this PMD problem, we hooked a laptop with AE scanner, and here are the codes we found :
several ones about shift,
others about IP. Note the PO266 showing : cylinder 2 injector circuit contribution / balance defaut
Despite these codes, she was running fine, except stalls
Yesterday, we received the new D-Tech PMD and install it, remote mounted on a heat sync (the one from SSDiesel kit), outside engine bay.
The guy crank, and shefired right away, idling like a charm.
He let her iddle for a while. After 5 minutes, she started herself idling down to 500 rpms and started stumbling hard, black smoke, and died.
He killed batteries to try starting her again, as she was stalling after few seconds.
Then, we tried to swap to the old PMD which was causing stall but was allowing to run fine : same result.
- We pull out the resistor from PMD (#9)
- We connected the PMD on the stock harness to see if te extension was fine
- we disconnect both batteries, then disconnect the PCM for a while
still no luck.
The AE scanner shows these codes
I forgot to mention that the IP is 3 months old and was said to be brand new..., remember at previous scan, that P0266 was showing...
What the hell mean these codes ?
After we disconnect the PCM for a while, cyl 1 and 5 do not show up in the code list, and she was running just a little smoother...
any idea ? we're a bit lost, and the young guy is really really sad and disappointed...
still no luck.
