Hard start, and smoke
racin83
I am havinga similar problem. Went to start my 97 CHevy Suburban 6.5L turbo diesel, and wouldn't start had to put accelarter to the floor finally after some hard cranking it started but ideled and ran VERY rough with alot of white and blue smoke pouring out of tailpipe. What could be the problem have been told could be possilbe injection pump.
racin83 your problem is different and you need to fill out the cecklist and post your own thread we will help but the checklist is the best way to get help
So DieselSlug, do you think it is my engine that took a crap on me or what do u think it might be?
Racin83 welcome to the site, I moved your posts to an independent thread, we have found it is easier and more effective to trouble shoot 1 vehicle at a time in it's own thread.
You haven't provided enough information as of yet for us to effectively assisit you.
1st thing you need to do, go to the user CP button and update your signature with your truck information.
Following that copy/paste the diagnostic sheet filled in with as much information as you know about the situation, don't worry if some of this is new to you we'll walk you through it, we have a reasonably high success rate with getting member trucks up and running again.
racin83 Welcome to DTR!
If you run threw and post up the checklist on here we could help you out a lot better than little amount of information that you have provided us so far.
It is very hard to diagnose a problem while working on and in front of the truck much less over the internet. The checklist was made to assist both the truck owner and the individual attempting to assist over the internet.
Just stating that the truck is hard to start and smokes could be so many different things wrong that, without doing the checklist, could make it to were we could give you bad advice and have it to were you would be wasting money on parts that are not yet in need of being replaced.
The more assistance you give us the better off we are to get your vehicle back on the road quickly.
Also if you could please fill out your signature, it will help us help you.
OK so I updated my signature but where do I find the diagnostics sheet to fill out.
Year: 1997______
- Truck model and class (ie: c2500) Suburban K2500_________
- Automatic or Standard __________Automatic
- Mileage: (indicate miles or km) _________230,000
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___________nothing yet
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ______________turbo
- Ambient outside temp: (indicate *C or *F) __________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _________Diesel
- What fuel additives are you using? ___________none
- Where are you located? _____________Michigan
[/B]- Air filter _________
- Fuel filter _________
- CDR Valve? _________
- Coolant – last flushed/replaced at _____________
- Oil – synthetic/regular, changed at ___________
- Batteries – state of charge, (matched set) replaced at _____________
- Battery cables and grounds (removed, cleaned and tightened): ______________
- Glow Plugs - how many miles on them? _________ What type? _____________
- Injectors - last changed at _______________
I just purchased this truck about 2 months ago and I haven't replaced anything yet just started giving me these problems
- What were you doing when it happened? ______________went to start first thing in the morning
- How was the truck running fine before this problem appeared? _____________yes my wife drove it to the store came home parked it and that is where it sat until the morning
- Has this problem ever happened before? _______________________no
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __n__ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? _________ hard
1b] Does the engine crank over? ________
1c] Are your batteries fully charged? _________yes
1d] Have you removed, cleaned, and tightened all battery connections? ________no
1e] Does your Wait to Start light come on for a time? How long? _a few minutes________
1f] Does your glow plug light come on? _________ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? _yes blue and white_______
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________yes
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___________
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges? ___________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______________
6d] Have you changed exhaust / downpipe / crossover? ________________
6e] Wastegate – mechanical or vacuum? ______________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
_________________________________
__________________
Sounds like your glows aren't cycling or you have several burnt out. Does it run smoother after it warms up? Will it start better after warming up?
Try to do the 2] Fuel issues especially the lift pump test.
There is a description in the FAQ for that.
Also check where your PMD is located. The stock location is on the driver side of the Injector Pump slightly hidden underneath the intake.
Spend some time in the FAQ section to educate yourself. There is a picture that is provided there to learn more about the parts and their locations and the name also.
Thank you for all your help the truck is fixed it was injector timming issues. Also I bad injector pump, We also replaced the fuel filter. Just want to let all who helped that its now fixed and I thank you
If you had a mechanic or the stealership fix it you never know what was really wrong, but they always replace the IP. definately still do the LP checkout, get a $20 vac/fuel pressure guage and test it. It can cause premature IP death, or hard starting. It could have also just be your PMD and not the entire IP was iffy.
