DieselAmateur
I'm pulling the tranny this weekend to swap in a new one, but wanted to post here in case I'm missing anything before tearing into it and can't get parts after hours.
Last April I did a new clutch, pressure plate, throw out bearing, fork, fork pivot, and slave cylinder. Clutch was NAPA brand equivalent of stock/ OEM
Transmission was rebuilt by a local shop in 2017 using takeout parts. Was never happy with the gearing as my ratios were off, think early NV3500 gears were used as my RPM to speed has never matched up. But the shop gave me a huge break on the job so I couldn't really complain.
Sometime around this spring/ early summer the trans started grinding going into 4th. No big deal, figure just bad synchros. Decided that if I was going to go through the trouble again of pulling the trans I'd want to put in a new one or do a full rebuild as I don't want to replace one part only to have another go soon after and have to pull everything again.
Then a few months ago the transmission starts popping out of 2nd when throttle is applied. I have to literally pull/ hold the stick in 2nd to stay in gear. Not ideal and pretty nerve racking when pulling a 3.5 ton mini excavator. So current trans has got to go.
After pricing things out on just parts alone it was more cost effective for me to buy a new rebuild from High Gear Transmission. I splurged for the cryogenic internals because of the P400 and future power mods yet to go on the truck.
The truck/ trans ran fine otherwise and sat for the thanksgiving break. Driving it to start the week I have to force into every gear. Hard to get into 2nd, slightly easier to push into 3rd and have to quickly pull into 4th, otherwise it just grinds and won't go in. I could briefly get it into 5th, but that's now impossible. So since Monday truck is essentially not driveable.
The master cylinder is full, pedal travels and feels normal as far as I can tell. With the truck off I can shift into every gear without issue. Running she doesn't want to cooperate no matter how many times I pump the clutch pedal. Last topped off the fluid mid summer before a long drive, have always used the specific GL4 fluid for this transmission. Fresh fluid was put in last year when I did the clutch, and the trans temp gauge has always read normal, so I'm pretty sure fluid isn't the issue.
I'm posting because I'm confused as to whether this issue is solely internal to the trans and will go away once the new one goes in, or if it's external to the slave/ bearing/ clutch assembly. It seems to be behaving more like a clutch/ pressure plate issue, but I just did all that a little over a year and a half ago and wouldn't think it would go bad this fast.
I was also advised by the folks at High Gear to go with a stock clutch and was specifically told to not get a South Bend or any other aggressive setup. Better to have some slip and save the trans, in their words. Anyone think otherwise?
So is there anything I'm missing about what could be wrong, or does anyone know what the more likely problem is based on my symptoms? I'm probably going to buy another clutch assembly before the weekend just to be safe since I can always return it. And I'll be tearing into it come Saturday morning, but always prefer to be more prepared for what I'm getting into, so I'm trying to cover all my bases. Thoughts?
