matuva
Tropical 6.5er
I know that when you get a blown headgasket or a cracked head, the upper hose from T-stat to radiator gets hard when you run the engine.
Do you have the same symptom when you get a cracked block?
I was wondering that, because on the 97 K1500 of my father in law, we did the heads.
We found water inside cyl #8, and so had the head tested. The head is supposed to be good, but unfortunately, after we put everything back, we had to face stumbling engine with white smoke, hard upper hose, and ... hydrolock---:mad2:
Obviously, something is cracked. Wonder wether it is the head or the block
