BigBlueChevy
Compression Ignition Addict
Alright guys, I've spent a good amount of time analyzing my front IFS, "name brand" IFS lift kits, and even more time at the drawing board. I feel like now that I have sufficent idea as to what I'm going to do, I'll pull info from everybody here with input and knowledge.
The plan:
-Convert the coil springs and shocks to Airbags.
The possibilities
-Air shocks(replace gas shocks and go in center of coils with same mounting fashion)
-Complete Air Bag system
The Reaon:
-Creating AT LEAST a 3" lift on the front end to fit 285's(I'm not telling the specifics just yet)
-Improved ride quaility through the use of being "Air Ride Equipped"
-Will allow a leveling by simply plugging in my compressor and charging(to eventual onboard air)
Problems:
1)line or air valve failure
Solution to problem:
2)
Mainly its to seriously up the ride quaility. I rode in my friends 3500 cummins 4X4 and he had used an airbag assist to lift his truck as well as make for one sickeningly smooth ride. So the rear end is taken care of for my truck. Now its time to work out a plan for the front IFS.
Right now I want to hear problems you think will occur with this this setup(don't be shy I want to hit EVERYTHING). I'll continually modify this post where it says "problems", and "solutions to problems" so that nobody has to scroll through miles of pages to find out where we are at and it makes tracking this easier for me.
Also, additional ideas will be taken into consideration. Should this work out well I will do a large writeup(yes with pictures) for others who wish to do the same or something similar.
Thanks guys
-Jamie
The plan:
The possibilities
The Reaon:
Problems:
2)
Thanks guys
-Jamie
