gutless
chevyCowboy
Springfield Nebraska
my truck has beel felling gutless, ideling very ruff, and is acting the same as it was a bout a month ago when the OPS went out. i put a new genuine ac/delco replacement in and all problems got better.
I opened the water drain with truck running and no fuel came out and the truck died after about a min. i then pulled the plug from the OPS and jumped the LP with air bleeder open and it pumped fuel.
could the OPS be bad again or do i have other problems filter was changed about a month ago as well
he is the check list from the last time noting has changed other than a few more mile on the clock, and it has not stalled so i am leaving that part out
- Year: __93____
- Truck model and class (ie: c2500) ___k2500______
- Automatic or Standard ___standard_______
- Mileage: (indicate miles or km) __258000_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___wg wired shut, ho water pump.________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____f_________
- Ambient outside temp: (indicate *C or *F) __80*-90* most days________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __#2_______
- What fuel additives are you using? ____none at the moment_______
- Where are you located? ___neb__________
- Air filter ___250K____3/09__
- Fuel filter ___258K___7/09___
- CDR Valve? ___229K__2/08____
- Coolant – last flushed/replaced at _______256K_4/09_____
- Oil – synthetic/regular, changed at ___rotella 15w40________
- Batteries – state of charge, (matched set) replaced at __replaced diehard platnum 3/09 good charge___________
- Battery cables and grounds (removed, cleaned and tightened): ____check 3/09__________
- Glow Plugs - how many miles on them? ___?______ What type? ______?_______
- Injectors - last changed at _____stock replacements 192K by po__________
- What were you doing when it happened? ____accelerating__________
- How was the truck running fine before this problem appeared? ___good__________
- Has this problem ever happened before? _______no________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __N__ And? _______
Diagnostics:
1] Starting:
1a] Does the engine start? _yes________
1b] Does the engine crank over? ___yes_____
1c] Are your batteries fully charged? ___yes______
1d] Have you removed, cleaned, and tightened all battery connections? _yes_______
1e] Does your Wait to Start light come on for a time? How long? ___dont have one______
1f] Does your glow plug light come on? ___8 sec or so______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ________
2a] Can you hear your lift pump working? ____no________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___no only a little steam not like it used to be when i drained the water______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___some________
2d] Loosen an injector line and crank the engine - does fuel come out? __yes ______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? __yes_________
__________________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___no____
5b] Any bubbles or oil film in coolant overflow tank? __no_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____no_____
5d] Excessive white smoke from exhaust on cold start? __yes_______
5e] Excessive black smoke from exhaust under hard acceleration? ___normal_______
6] Performance Issues
6a] Do you have gauges? __yes egt and boost_________
6b] Maximum boost under load? __12-13__________
6c] Have you added a performance PCM (reflash) or Chip? _____na_________
6d] Have you changed exhaust / downpipe / crossover? __yes from ssd 3" dp 4" exs ______________
6e] Wastegate – mechanical or vacuum? ___stock but wired shut___________
7a] Single or dual thermostats? _____single_______
7b] Have you replaced them lately? Manufacturer of replacements? __rep at 228500_______
7c] Have you pulled and cleaned Radiator and coolers lately? ___yes_________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____no____
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
_________________________________
__________________
__________________
When was the last time you changed the OPS?
When I change the LP I also change out the OPS or vise versa. If either is still good then I got a spare!
if connector on ops and no fuel, then bypass ops and get fuel then its a bad ops. I agree that you might check fuel filter but only with reason to determine if lp is pulling excessive amperage burning out the ops contacts
pull the connector plug a wire into the orange (hot wire) and grey
(LP wire) I just changed the filter a month ago and the ops should i try and do both again
I just dealt w/ this same issue a couple weeks ago. New ops and LP and still stalling. I ran some wires from the lp to the batter and jumped the pump and drove about 20 miles and it still died out. The pump and IP were good. The filter was new as well. That only left one thing the fuel tank. Lot's of junk in their from the fuel stations. filtered the fuel into a doubled up old sheet over a 55 gal drum. Then blew out the fuel lines, cleaned tank and reinstalled. All good now. That is the next logical step.
chevyCowboy, you may want to do the relay mod for the OPS/LP. Search it here, there was a long thread about how to do it. Or check in Kennedy Diesel website if you want a ready made one.
i was suspecting a problem with the wireing btwn the ops and lp so i spliced in a 12 volt source off of the turn signal fuse. using this thing i found at the autoparts store that gives you an extra spot in the fuse pannel and has a pig tail off it. so i ran that to a switch and the switch to a splice directly behind the Ops connector. with switch on Lp runns great never a problem(funny part is that the truck will continue to run after ingnition is off, i dont get it beacouse there shouldnt be power to the turn signal fuse when the ignition is off? any ideas) so i guess i will go get a new ops tomorow hope the dealer will waranty it or something only had it alittle over a month
Do the relay mod on the OPS, so that the OPS triggers a realy made to handle the current better.
You can jump your OPS on a 93 like my 94 by bumping the top of the fuse on the passenger firewall up against one of the battery junctions next to it. Check the fuse too.
